DanTheMan »
https://forums.nicoclub.com/dantheman-u149532.html
Thu Jan 14, 2010 4:10 pm
It all depends on the time at which you observe the "smoke". Since you are in NY and it is cold, you will tend to see condensation coming from your exhaust pipe. This is normal and is nothing more than your exhaust system, i.e., the muffler and converter. However, if you drive for a considerable time and it still emits this, then you have a problem mechanically.
If my old hot rod days serve me, a "white" smoke is more valve related and a bluish smoke is more piston ring related. I would venture to say that, since this isn't a GM or Chrysler, it is moisture related and perfectly fine.
Cheers!
