oil burns bluish, coolant and condensation are white.BoostsFed wrote:the white smoke is oil burning, it may be a problem IF after warmed up to operating temperature and you still see it...but after warm up and it went away, you should be ok. do check your oil level frequently.
240240 wrote:hesistant
Carl H wrote:hestiant
Mine will miss if cold and boosting. Goes away after it is warm.240240 wrote:Thanks.I kinda thought that I just wanted to make sure.You ever experience a "miss" when cold or under boost?
