WHITE SMOKE!! PLEASE HELP
!92KAhatch!
Car: 1992 nissan 240sx
names james
got a 92 hatch
still rockin the stock KA24de
does any have any suggestions as to why my car is spitting white puffs of smoke when i step on the accelerator.
usually on does when i go from a stop.
pretty sure its oil being burnt but why is it doing that???????
nissan24009
Car: nissan 240sx
pretty sure its oil being burnt but why is it doing that??????? [/QUOTE]
make sure its actually white smoke cuz white smoke = burning waterblack to bluish smoke= burning oil
Tagline262
If its white smoke, you most likely have a bad headgasket.
Bad smoke = bad piston rings, bad valve seals dumping oil into the chamber.
Tagline262
If its white smoke, you most likely have a bad headgasket leaking coolant.
Black smoke = bad piston rings, bad valve seals dumping oil into the chamber.
Klits562
Car: white s13 coupe
double double post!!!!!!ya its probably a headgasket how does the car run and whats the weather like in your area?let the car run and put your hand over the exhaust for a few seconds and smell your hand if it smells sweet then its coolant and your headgasket is blown.If your car runs fine and its really cold in your area it may just be condensation but it shouldnt be very thick.
!92KAhatch!
i live in southern Arizona (around Tucson) so its dry and its never really that cold.
the exhaust does smell a little sweet...ish and its not a lot of smoke, most of the time.
(JUST TO CLARIFY FOR EVERYONE ITS BLOWING WHITE SMOKE NOT BLACK)
