white smoke (part2)
b dog
Car: 300zx tt
ok i went aprox 4 miles and when i stopped smoke was coming out from my hood. so i look at it and i was over by the battery so i took my battery out and found some liquid everwhere and cant seem to find a leak. so if anyone knows on wat to do i would love the help
-thanks
Q451990
Please describe the color and smell of the liquid...
Also, check all of your resivoirs... power steering, brake, transmission, etc. for low fluid.
Heath
b dog
Car: 300zx tt
so i figured that it was coolant and i checked my rad and it was way low but the problem is now where is it coming from?
Q451990
Sounds like it's big enough that you should just be able to fill it up and then look for it while the car is running and idle.Or you can get a loaner tool at most parts stores that will let you pressurize your cooling system - so you'd fill it back up with water, pressurize it with this tool, and then look for the leak.
Heath
robomatic12
Car: 1990 300ZX TT
There are a bunch of coolant lines running at the back of the block, somone I know had the lines bust on his TT. Definetely pressureize the system and try to find the leak.
labcoatmonkey
Car: 1991 300zx JDM TT I miss u 01 alty
^^ was that person me?
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
yup, lots of small coolant lines, the go across the back of the motor and under the plenum up to the tb's, and are a common issue as these cars agi
