I have just put my engine back in after a pull. The only reason I pulled it was to clean up/paint the bay, change clutch, do some heat wrap/shielding, and add an upgraded oil cooler. I did take off both manifolds and the turbos (gt600s about a year old) to do some of the heat wrapping. I ended up changing both O2 sensors just because they were old originals. Didn't do anything internal. I did a vacuum test to make sure I didn't have any air leaks after I put everything back. Before I took out the motor I did not have any smoke out of the exhaust but now I have white smoke out of the right exhaust pipe when looking from the rear
. The smoke on start up is almost not noticeable until you give it its first rev. The smoke kicks out when you rev it and appears to be thin and not dense. After you rev it and it's back at idle you can faintly see a stream of the smoke flowing out. I noticed when you put your hand over that exhaust pipe the flow of air doesn't seem nearly as strong as the left exhaust pipe maybe not an issue or a sign of what's going on. The car idles perfectly fine, the temp at idle is good and the oil pressure sits between the first white line and 60 but closer to the white line. I have yet to drive it as I do not want to cause any problems till I have a better idea to what the issue could be. I am so stumped. Is there anything I could of done during the pull and put back that would now lead to this? Any help is appreciated!
