ScottJackson »
https://forums.nicoclub.com/scottjackson-u14976.html
Sat Oct 20, 2007 12:09 pm
YES. Put some of the stuff in the coolant that reacts to combusted gasses being present in the coolant. If it says you got compression getting into the radiator, you got problems. From there, pull all the spark plugs. One will likely be substantially cleaner than the others. That'd be the cylinder that's getting coolant in it. Aluminum expands twice as much as iron when heated. Overheating any aluminum engine or engine with aluminum heads usually ushers in the end of that engine... very quickly. I don't know why manufacturers don't put some ignition disabler that shuts the car down when the block/heads get above a certain temperature, especially in the aluminum engines (which is almost all nowadays). I know it could be dangerous in an emergency situation, but make a dummy light come on at say 250* saying the engine will shut down from heat soon, then at 260* have it cut power to only 4 cylinders and have the dummy light start flashing with maybe a beeper too. Then, 15 seconds later have it shut down until it's reset below a certain temperature.
