onthecreek wrote:hi,
new to the forum, never had a problem with our 03 Murano SL until recently.
have had it in to the shop before and they weren't concerned but i am. the check engine light is on again and it seems to be making more noise than before. it might be better described as tapping.
symptoms:*on start-up there's a poof of white smoke, both exhausts.*sometimes the engine will stall seconds after starting, starts right back up but i give it gas.*BIG PROBLEM...engine knock after going to same speed for a few seconds. it seems to be getting worse. it doesn't happen when accelerating from a stop, speeding up will make it stop when it happens. the last oil change, there was no metal in the oil according to the shop. the check engine light is on again.
i plan to take it back to the shop but don't want to get a run around. i'm sure they want to get paid to fix stuff but does this sound familiar to anyone? i'd like to be more informed when i talk to them.
thanks!
1. White smoke on start up is normal on cold mornings, IF you have no water in your oil and no oil in your radiator, this is normal. If you have white smoke constatly throughout the whole day and overheating.....your head gasket is shot.
2. Engine stalls after starting. You will need to perform an idle air relearn and/or throttle body relearn as your mechanic must remember that the Murano is a "drive by wire" vehicle. Anytime any work is performed on the throttle body, you need to perform this afterwards. Most mechanics forget to do this.
Before you perform the idle air and throttle relearn you will need to do an ECU reset to clear all the codes. This is the only way you can perform the idle air and throttle body relearn.
3. Change your MAF sensor. Do not clean it as this will do nothing. The MAF sensor on a Murano uses electrons instead of heated wires, and there is only one exposed resistor. Look at it yourself , you cannot clean it. Buy a new one. The MAF will not throw a "code" as it will work within the minimum requirements. The only time it will throw a code is if it is completely dead and you are stranded on a deserted road. Don't buy a MAF from the dealer as it is $500, go aftermarket OEM.
