TnF »
https://forums.nicoclub.com/tnf-u157228.html
Fri Mar 26, 2010 2:35 pm
Hi! I am a proud owner of a nissan 200sx(s13 with ca18det-i live in europe)I bought the car 3 months ago an it has some small modifications. Anyway about an hour ago, starting 1st with full throttle changing to 2nd, i heard a noise and no boost:S I stopped the car aside, checked it and brought it home.I don't know exactly what happened but here some info to help me:1) I get no boost--(vacuum to 0 boost-runs like NA)2) the wastegate doesn't seems to work- the actuator may be stacked /or getting no boost to close/open the wastegate)3)I am getting white smoke(don't know if its oil or coolant) from the exhaust4)The turbo it isn't the stock one, but its a nissan made borrowed from an rb engine(don't know which one) and is bolted to a T25/t28 manifold. Also I don't know if it is t25 or t28, because there aren't any markings, but i can see that the intake housing is bigger than the exhaust housing of the turbo. Also the boost line that is connected to the wastegate actuator is connected direct to the intake housing of the turbo 5) My timing belt is the stock one and hasn't changed yet(is there a chance that the belt "slipped"6)I haven't check any of fluid levels yet, because is late night here, but i haven't seen any warning lamp or high temp when i was coming back to my house7)the engine seems to run smoothly.
Please help me!:S
Modified by TnF at 12:24 AM 3/27/2010
