White smoke from oil catch can SR20DET
For discussion of front-drive SR20DE, SR20VE and SR20DET engines!
Anikin
Car: Pulsar X1R
SR20DET
T25 blah blah blah
Heyo, I noticed a bit of white smoke coming from the filter on the top of my oil catch can. The catch can is set up with 2 hoses:
1. 1 hose running from the catch can to the vent just to the right of the exhaust manifold. (what is the tech name for this vent?)
2. The other hose running from the catch can to the fitting on the right rear corner of the rocker cover, just behind the distributer.
Any info about why smoke might be coming from here, and how to fix it would be mint.
Thanks.
boost_boy
Sounds like a bit of a worn engine to me. Does your catch can fill-up with oil or is there just smoke coming out of your catch can? At worst you might be experiencing "blow-by" which is the result of worn piston rings.
Return to “SR20DE / SR20VE / SR20DET Forum (front drive)”
