OutToWinPAHC »
https://forums.nicoclub.com/outtowinpahc-u66900.html
Fri Dec 05, 2008 12:09 pm
boring requires a total bottom end rebuild, you may not need. You can get a compression tester for under 40 bucks, and there is a write on on here. Its easy to do, but its not for you.
At this point checking compression is not your option. If you have a coolant in your exhaust, your going to fail the compression test because the air is going to push into the cooling system through the damaged head gasket.
Pull the head clean it with a razor blade and gasket cleaner, then take it to a machine shop and get it check and milled if needed (should be cheap my local machine shop charges 30 to check, 40 to mill).
If its good check the block, takes 10 minutes after you clean the deck. Then put her back together or have someone do it for you. Since the head is allready off and your buying the parts it should cut down the price. I would estimate installing the head will take 2 hours then you gotta put all the here and theres back on.
A head gasket, head bolts and a timing chain will run about 150, or you can upgrade to reusabe arp heads studs. Head bolts are torque to yield and cant be reused. But as long as you didn't over heat it it should be a cheap fix.
