NoStickers »
https://forums.nicoclub.com/nostickers-u8034.html
Fri Apr 16, 2004 8:37 am
About two weeks ago I drove my 91 sr implanted 240sx for about 10 minutes just to get to the mall. Everything ran perfect. When I left the mall I started the car and backed up but loads of white smoke poured out the exhaust. It was A LOT of smoke. My car wasn't overheating, I wasn't low on coolant, had the right amount of oil, then I remembered that I had plugged the vapor catch canister line from the gas tank when I did the swap. I took off the gas cap and a I heard a big woooshh from sucking air. I waited a little while and started up the car and there was no more smoke.
About two weeks later (today) I drove the car for a about 10 minutes once again. I was shifting at about 2700 and didn't notice anything wrong. I'm trying to get over in the next lane but this guy in a starion is being an a$$ so at 30mph and in 2nd I try to give it some gas but I'm not going as fast as I normally do. After that I tried to shift a little higher to see how bad it is. It was pretty laggy, not the normal punch I get. When I get to my destination I'm there for about 10 minutes and then I leave. Only when I start to back up, loads of white smoke pour out my exhaust. I check the gas cap but I never tightened from before so there was no vacuum in the tank. Coolant is good. What could be my problem?
Oh the smoke smelled bad if that matters. Thanks for any help I can get.
EDIT: I just left it in the parking lot so I havn't tried driving it with the smoke coming out.
