White smoke coming out beside battery
hetterbr
Car: 1990 Nissan 300zx - Right hand Drive
I have a 1990 300ZX twin turbo. it is a right hand drive.
Not sure if the engine bay is designed differently than american version.
The battery is located on the left side, fairly close to the windshield. When the engine runs for a bit and gets hot, we get white smoke coming out beside it closest to the engine. it has a smell, but i can't decide what it smells like.
Ideas?
thanks in advance
grayman_TT
Car: 1990 Nissan Fairlady TT
Does it smell sweet? Have you noticed any fluid under the car after parking for awhile?
BioJammer
Car: Na Z32
Manual swap
Dinan Ecu
Also possible the battery case has split.
hetterbr
sorry, been away from the computer.
We put a new battery in about a month ago.
The smoke almost has a burnt smell to it. not sweet at all. oil level has stayed the same since i changed it about a month ago. also the anti freeze level has stayed the same. i haven't noticed any leaks.
today it almost had a bit of a gas smell to it.
it doesn't happen every time it is started either. very weird.
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
There's something back there leaking and burning then. That's where your turbo is, and those lines are prone to leaks. See if you can't get a better look at the turbo feed lines.
hetterbr
AAhh. didn't know the turbo was back there. thanks.
I will try to get a better look down there.
