white plug by eccs plug?
Indecisive
Car: 1987 200sx Turbo
does anybody have the pinout for that white plug by the ECCS plug?
It's supposed to connect to the main harness and be connected to things like ECCS relay, fuel pump relay, ignition power, eccs back-up power, etc...
I believe it's either Plug number F1 or F3.
I tried to figure it out by looking at my PDF FSM, but in that section, things go upside down alternately and I can't keep track of where the wires are going cause they're going across multiple pages.
I need to hard wire these things in cause it's going into an S12, and the colour of the wires posted for this swap don't correspond to the color of the wires on my plug, and I'm not the only one.
So, a pinout would be greatly appreciated.
float_6969
do you mean the white plug that goes up into the dash on the S13?
Indecisive
yes...
it seems that in the S12 community, information was skewed. All the write ups said that all those wires are on taht white plug, but I just found out, that only things like start signal, water temp, and oil pressure are there, and the others are on a different plug...
that would explain why I could locate those wires (temp, pressure and start signal) but not the others (eccs power, back-up power, eccs relay, ignition power, etc...)
(it didn't make sense to me that those things wouldn't be on the ECU plug.....apparently...my concerns were justified...)
dattodude
Car: CA18DET Datsun 1200 B110 Sedan
If you are looking for a second opinion..
Yeah.. on S13 the white flat rectangular plug is for the dash loom.
Indecisive
thanks guys.
Found out which plug I need to wire into for the other stuff.
