Jostudly wrote:I am not sure I want to spend a lot of money on HID's so I am wondering what is the best 9005 bulb (low beam) that shines the whitest light? I see a lot on the road that have a purplish tinge to them which I do not want.
as stated prior, h11 is the low beam, and 9005 is the high beam.
i just want to also clarify that unless you find a higher wattage bulb, no matter what color the glass is, its still going to put out the same amount of light. thats part of the marketing scheme out there, that companies use to trick unsuspecting buyers = blue-er color tricks people into thinking "brighter". (when its really the complete opposite). the brightest light you can have is 4300k - 5000k. that is as pure white, as it gets. anything blue = reduced light out-put.
if you do end up buying a higher wattage bulb, take caution as it will consume more power, and place your headlight bulb wiring harness into stress, causing the insulation to eventually overheat, reach its peak, and begin to melt = exposing your wires = shorting out your whole car. its a messy, slippery slope that i wouldnt even go near. your car is designed for 55wat low beam, 65watt high beam. any more and you will also begin to melt your inside reflector housing & headlight casing itself.
save yourself the money, hassle, and time = buy a 35watt 4300k HID/xenon kit and install it. its plug & play now a days, and requires minimal experience under the hood. the HID/xenon kit is the real deal, and will dramatically improve your night time driving, versus just play color-tricks on you.
