Awww hell. I get white smoke at startup (and a lot of liquid/moisture) and after running seafoam, I cleaned my spark plugs to find a hint of oil on them.MikeYeeS13 wrote:Check all your plugs to make sure there is no oil on them (piston ring blow by) This just happen to my DSM.
Damn thats good to hear, at least some hope. loljamie wrote:could be just condensation inside the system being turned back into steam. My wifes 2002 rav4 does this on start up occasionally and the thing is still mechanically perfect However a comp check wouldn't hurt. Knowledge is always good and it gives you a base line for later if need be. If you have reformulated gas where your from that could be a contributing factor as some of that stuff produces h2o as a byproduct of combustion
