Q451990 »
https://forums.nicoclub.com/q451990-u142.html
Tue Jul 15, 2003 7:15 pm
I'd say you have a loose electrical connection (MAF, CAS, etc) that was causing your problems. If your problem at idle was more of a "bouncing" feel, I'd point to an injector. In any case, the gas thing is BS - I'd check your electrical connections on the sensors at idle and see if the problem comes back. Any change in idle speed indicates a problem. You'll see it again eventually, but you'll be better off finding it at home than on the road somewhere.
Heath
