94Q45Beast »
https://forums.nicoclub.com/94q45beast-u244772.html
Fri Sep 11, 2015 5:54 pm
I'll pick up some permatex grey on my way home if I ever get to go home and take pics of the white stuff so other nico members who experience it can know whats up......one more issue...as you guys know I've done some work on my Q but I'm still not getting proper mpg's....I'm getting 17ish mpg's city and 23ish high way....but soon as the gauge hits the half way mark I start to get 8-11 mpg's city and 13-15 mpg's highway.the fuel pump was changed 40,000 miles ago and the FPCU was still in "excellent condition" according to Infiniti dealership back in 06(40,000 miles ago was back in 06 for my Q) also on every 4th full tank I fill up I add a bottle of 104+ octane booster with fuel system cleaner....as you guys know I don't like to cut corners when it comes to maintaining my Q, I only fuel up from a select few....BP, Shell V-power Nitro, Chevron w/ techron, and Exxon Mobil....so whats going on? I initially suspected my fuel hose to be loose located by the IAC Valve but it check out fine then I presumed that my problem was oxygen sensors?...is that it?...or could it be something else...I don't get any lag in power, its nice and smooth as it should be, but sometimes the VVT kicks in a little too much when I'm trying to pass an idiot on the freeway but that should be normal....all my sensors are fine.....no rough idle......the only thing I cheaped out on was the pcv valve hose which did drop my idle a little. but this random fuel consumption is driving me crazy. you guys know I've cleaned everything that should be cleaned.
