bcar240 »
https://forums.nicoclub.com/bcar240-u13477.html
Sun Nov 07, 2004 2:53 pm
is it like a goopy film or more flakey? I know that they use a sticky, white sealer around the plastic cover inside the door, some of it might have got on the rubber around the window and is getting spread around. You should probably take the interior panel off regardless and check it out. If it is corrosion, you might need to fix whatever is causing it. It is not really that hard, a 10 minute job if you know what to do.
