White Calipers
All things Altima Coupe.
Infantry1327
Car: 08' Nissan Altima Coupe SE
I haven't really been on the forums much but figured I would let you know I painted the calipers on my coupe white. I haven't seen anyone else with white calipers
I was a bit lazy and didn't really have the proper tools to completely take off the calipers so I just taped everything else and kept them in place. I put on about 5 coats of high heat white paint, and 5 coats of high heat clear coat. So far so good, came out real smooth and haven't really been gathering to much brake dust. But it has only been about 5 days. I also changed my front brake pads. So hear are some pics. let me know what you think and i will try and get some better pics soon.
czonin
Car: White 09 Altima Coupe 2.5S
Nice job, I was originally going to do mine white but just ended up going with red. Next time use a garbage bag to cover around the caliper, itll save you a lot of time.
DReed86
Car: Altima Coupe 2008 SE 3.5 White CVT
Looks sick bro....
I want to get Brembo brakes but Im too broke.... maybe white caliper covers are in my future
Infantry1327
thanks, the next step is some slotted drilled rotors
nismogxs21
Car: 08 Altima Coupe 3.5
woww they came out really good bro :dblthumb: definitely a 2 thumbs up
i jus hope they dont get to dirty after time
Richice87
Car: 2010 Nissan Altima Coupe 3.5SR White With Red Leather Interior, 6spd mt
just a quick question bro. I notice you painted it with the calipers installed. Did you take the brake pads when you painted it or you painted everything including the brake pad?
Infantry1327
I took the pads off, I also took the rubber gromets and the little brackets that hold the pads on. It was quick and easy. I had to change my front brakes and figured I would paint the calipers while I had everything a part. The next day I painted my buddys calipers red, he has a 350z. If they get to dirty I will just re do them. It takes about a day to do. Mostly because of drying time. If I do it again I am going to order some white caliper instead of just high heat paint. The caliper paint is thicker and repels brake dust better.
aphu
hey bro i know this is a pretty old post but im planning on doing my calipers white also. i just wanted to ask how is the brake dust? how often do you have to clean them??
Infantry1327
It's not to bad, if you clean them regular. and by that I mean get a nylon tire scrub brush, and give them a quick scrub when you wash your car. And i don't recommend using the clear coat. The clear coat actually gives them this dirty yellow tint, I do recommend instead of taking everything off and tapeing everything up. Just wrap the rotor with a trash bag, let the caliper hang from the brake line, give it a decent sanding, and spray.
aphu
Alright man preciate it
supra11
Car: Honda Accord 1997
Nissan Maxima 2003
Infantry1327 wrote:Altima Coupe Replace bumper support bar
Hey I saw your write up on this Altima Coupe Replace bumper support bar. Any pictures, need help for my maxima.2003-nissan-maxima-front-end-t557194.html
