Chugpuppy »
https://forums.nicoclub.com/chugpuppy-u151085.html
Wed Apr 07, 2010 10:25 am
"Now the pressure plate and clutch disc are varied. We used the stock setup of the afor-mentioned 93 D21, but common clutches used are off the 280Z Turbo, the 300ZX Turbo, and the RB series clutches. You can use both aftermarket and stock as long as it is 240mm. But one rumor surrounding this special is the truck and 280Z clutch can hold balls of torque, some saying near 400ft/lbs and they still retain stock pedal feel and longer life than aftermarket clutches. I'm still searching for the answer, but I read it went on Mike Lee's T66 KAT, and it had no problems holding 500rwhp."
Yeah I had read that article several times lol, it seems that it is the only informative write-up out there... He says that the "truck clutch" (referring to d21?) and 280z clutch can hold near 400ft/lbs of torque, anyone want to confirm this? I'm only looking to make 250-300 hp on my future ka24det build, but want room to upgrade. Plus, who can turn down a $200 clutch setup that can hold those numbers?
