white bulbs turned my dash blue...
wangless
Car: '02 MBP WRX
so i put in some white leds from http://autolumination.com/194_marker.html the convex ones that spread light out... so anyway, while the gauge was out i was looking at the leds turn on/off without the clear plastic thing. those leds were really bright. then i put everything back together and wait for night time to check out how white they are. but then came night time and then i turned on the dash lights... then they were all blue, except for the right corner, i left that in there to compare/contrast. i believe that they turned blue bc on the back of all the gauges they are actually transparent blue... i guess the white wasnt bright enough.
i was hoping that it would turn out white numbers with red needles... since the numbers are blue, the red doesnt come out as well, i think ill get some red bulbs next. just wanted to post about my experiece.
Looks cool!
Mr1der
agreed, other than the lack of the visibility for the needles, that blue does look really neat:)
wangless
Car: '02 MBP WRX
i wonder if i put in red bulbs... would they make it purple... red+blue = purple... i hope not
yeswepromise
i put red bulbs in my cluster.the cluster is now red.simple as pie.
D1SR240
Car: 2002 BMW M5
1991 Nissan 240SX
the blue clock looks kinda neat
wangless
Car: '02 MBP WRX
"i put red bulbs in my cluster.the cluster is now red.simple as pie."
i put white bulbs in my cluster.the cluster is now blue.not as simple as pie.
at least using white that is
MainEvent212
Car: 95 Nissan 240SX SE w/ SR20DET+goodies
it's probably that "hyper white" crap...
get some brighter bulbs too! that's gonna get u killed!
wangless
Car: '02 MBP WRX
theyre leds... link is in the first post i think. they arent that dim. if you shrink the pic... itll be more bright.
nissanrcer240
Car: 90 Nissan 240SX SR20DET
Thats looks tight in blue, can you see it better in real life, like the gauges and needles though? B/c you cant really see too much through the pic
wangless
Car: '02 MBP WRX
the blue is better in real life... the needles suck *** bc theyre red... they dont come through as much... i might just get some red leds next
jdmfreak
Doesnt loook too bad. Just brighten up the needles and you're set.
wangless
Car: '02 MBP WRX
"Just brighten up the needles and you're set."
only if i could...
Bluefire
LED and bulbs are different... Red LED's will only shine red.... so if there is a blue filter... it probly wont shine through. Red bulbs on the other hand will shine through but will mix with the blue filter and wil probly give off a green...
-Bluefire
wangless
Car: '02 MBP WRX
"i put red bulbs in my cluster.the cluster is now red."
that contradicts what bluefire says...
"Red bulbs on the other hand will shine through but will mix with the blue filter and wil probly give off a green..."
wangless
Car: '02 MBP WRX
ill order some red leds maybe this weekend... ill post back in about a week when i get them
wangless
Car: '02 MBP WRX
i wish my needles look like the one on the rsx
Smurf6x6
Car: 93 CA18 Coupe
i only got a RPM needle.;)
jdmfreak
What happened to your spedometer needle?
Smurf6x6
Car: 93 CA18 Coupe
My car came with the digital cluster, with the hugh center tach.:D
wangless
Car: '02 MBP WRX
"What happened to your spedometer needle?"
nothing, its just hard to see because my needles are sharpied red. why you ask ? because my initial plan was to have white numbers with red needles, which by the way look good in the day time. but the blue doesnt seem to mix well with the red. so therefore they are not as visible. but if you look closely, you can kinda of see the needles for the speedometer/tach. the fuel/temp is another story =(
jdmfreak
No no no I was talkin to smurf6x6 cuz he said he only had an RPM needle.
wangless
Car: '02 MBP WRX
oooh... sorry
in about a week i think ill get some red bulbs... so ill post again... or maybe ill make a new thread
midnightsliding
dose someone have red gague cluster and could u post a pic of it? thanks
wangless
Car: '02 MBP WRX
someones done it on an s14, just seach. id search for you, but the fuction hasnt been working for me.
jdmfreak
Is there a way to get them to look like the pic of the RSX?
MainEvent212
new gauges lol
wangless
Car: '02 MBP WRX
haha
mine kind of look like the RSX in person... except for the red needles =(. damn worthless $300 3.2MP digital camera...
it really does look brighter/better in person
jdmfreak
nismod do you have an sr or just different guages?
wangless
Car: '02 MBP WRX
i have an sr speedometer... the whole gauge was only $15 ! haha... so i put that in there a few months ago
currently saving up for a CA... hopefully gonna get hooked up from a friend to cartune
you finally realized it looked a bit odd to see 180kph ? or were the numbers so hard to see that you couldnt read the numbers
