whistling noise coming from around my crank angle sensor( sr20det)
TheShadow240
Car: 1991 240sx sr20det
I noticed the other day a wistleing noise coming from the area around my crank angle sensor, while at ideal, once the car is reved it goes away. is the a fix for this or is it for sure just a simple replacement part requirement?
ie.. buy crank angle sensor and swap them out then whistle will be gone.
looking for the answer asap.
Thank you !
Modified by TheShadow240 at 8:27 PM 7/14/2005
TheShadow240
need help with sr20det crank angle sesnor problem, i have some whinning or whistling coming from it, what do i need to do ?
