Whistleing Sound and a ringing sound
DenverQ
Car: Tryin to make a living, Driving/Fixing my Q and my Beautiful Baby girl =)
When I start the car up now it sounds like its ringing and whisteling I lift the hood and it doesnt sound happy I have no clue where the sound is coming from. It seem to go away or atleast quiet down when I have driven the car for a while. Kinda sounds like either bearings or a vacum leak but the car runs pretty smooth. I might just have to take it to the dealer =(
DenverQ
Verified with the dealer and the water pump was replaced at 91k, so that shouldnt be the problem as I flush the cooling system every year. COuld the sound be another pully starting to seize up? It really doesnt sound like a air leak but like somehting is rubbing together type of thing
911/Q45
Car: 1990 Infiniti Q45
1996 Porsche Turbo
The idler pulleys that are used to adjuct the belt tension are probably bad at your mileage. Loosen the belts and check them, they should spin freely and silently.
greg_atlanta
Car: 2008 G35 Journey Sedan, silver/black (no sunroof), 1992 Q45 (in a past life)
When my idler pullies were bad I got a screeching noise at high rpms only. But I replaced before they got too bad.
Rev the engine very high and if the sound is amplified it's probably the pullies. They're about $40 each, might as well replace all three (PS, A/C, Alt.)
