djwarner »
https://forums.nicoclub.com/djwarner-u152452.html
Fri Nov 26, 2010 7:35 am
This sounds like a classic bearing problem. With the wheel turned to the right, the bearings experience side loads.
As a first diagnostic step, I would suggest jacking up the front end until both front wheels are off the ground. Use jackstands for safety. Turn both wheels by hand. Bad bearings may feel gritty or lumpy. Then check for excessive side play.
If the bearing feel ok, double check the brake caliper assy for free travel left and right.
I wouldn't be surprised if you found the problem to be one or the other.
