VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Sun Apr 10, 2022 10:38 am
That's way, way too long, so yes, get that fluid out of there. CVT's have no clutch material to make "ATF soup" like a conventional tranny, so there are no concerns about screwing up the Valve Body by changing the fluid like there would be on an A/T. It may already be too late if it's the front pump making the noise, but if not, fresh fluid in a hurry will be your only chance at saving it. Since a D&F only changes about half the fluid, if the first one improves matters, I'd recommend one or two more D&F's in quick succession to void at least 3/4 of the old stuff.
