Whining Noise?
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
have a CA18DET, all stock except everything listed below. I've been driving it the past month and its been running/driving/boosting fine. Started it up today, took my friend home, no problems.. a few minutes later, i noticed that when i would start hitting boost, there was this "whining noise", like a supercharger? oil level, pressure, and temperature are all good. turning the elec. fan on/off didn't help, and it does it primarely in gear, and a little bit at around 6-7.5k in neutral.
any ideas? maybe the alternator or alt belt? im puzzled as it just started out of nowhere. i may also mention that i have a stock water pump and alternator. i recently tightened the alternator belt as well..
Modified by sjbsuperman1425 at 1:51 PM 4/24/2009
S14toRPS13
Sounded at first like a bad fan clutch, but you said you have electric fans. I'd loosen up your belts and check your pulleys to see if they spin freely. Also, could be that you overtighten your belts too.
sjbsuperman1425
CA18DET
i had tightened the belts about a week ago and it drove fine, but ill check it.
it doesn't sound like the turbo to me, since the noise isn't as loud/consistant as when in gear.
sjbsuperman1425
CA18DET
i should mention that i dont have Power Steering so thats out. i took it for a test drive and it kind of comes and goes..
sjbsuperman1425
CA18DET
took it for a test drive and it the noise is definatley boost dependant, but sometimes doesn't present until higher in the RPMs. maybe turbo-manifold gasket blown out?
check shaft play on turbo and it is minimal. no boost/vac leaks. there MIGHT be one on the elbow coming off the turbo but i have no way of checking right now. when i get home tonight i'll probably throw some permatex on it..
sjbsuperman1425
CA18DET
http://www.supraforums.com/for...98750
last post, watch video. thats what it sounds like.
sxdime
Car: 95 240SX 97 Wrangler (wifes) 2000 Freightliner (workhorse)
Make sure to check all your boots (rubber hoses) that go to your cooler too. The will make a whisting - whining sound if they leak or get a small hole.
ZOMG.SR20
Car: 1990 s13
BOV not holding or WG not holding idk
sjbsuperman1425
CA18DET
no BOV. but i think i have a VERY small hole in the cold IC pipe.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
My LS6 sounds like it got a damn procharger on it. Its a bearing going bad on my tensioner. It may be a pulley bearing or tensioner for you as well
sjbsuperman1425
CA18DET
thats another thing i was thinking. but my sound is boost dependant. as in when it flutters from the compressor surge, the sound does it as well. ( i think)
sjbsuperman1425
CA18DET
well fixed a boost leak and it stopped making the noise. i'll report back in a few days to confirm diagnosis. Thanks.
