Whining Differential
trpower7
I have a rather odd problem with my rear end. Recently a very distinct whining occurs from rear end at roughly 40MPH. The whine is worse when the car is not under load (with the clutch disengaged) but is still present under load. Recently I was in a race and touched the redline (of course) in second and as soon as I let off the clutch to put it into third a loud whirring noise came thundering from the back. No visible evidence of problems, I am suspect of the differential. Cany anybody verify this?
AunVoh
do you have oil in it? is it the lsd or open? it also helps when you post about your car if you say what kind of car you have.
juazam_186
Car: Cars & Computers
Have you checked to see hoe much lubricant is in there.You should start there first.Is it a LSD???
juazam_186
juazam_186 wrote:Have you checked to see hoe much lubricant is in there.You should start there first.Is it a LSD???
p.s.Sorry about parrotting Aun Voh.They are basic questions to your problem.:arcadefre :peace
AunVoh
juazam_186 you want to fight don't you? i'll handle this the most grown up why i know..... copy cat copy cat.
trpower7
I'm checking the fluid right now, but I just changed it to redline a month ago, and I know it was full then, perhaps I've sprung a leak, there is alot of fluid junk down there, but I'll make sure.
Nismo_Freak
Car: 89 Nissan 240SX
Whirring often is a dry situation in the Differential ... are you sure its a stock differential? If its a KAAZ unit they often whine.
trpower7
Well I ripped the old one out and put in one from a junkyard and the whirring problem was solved. The old one was totally stuck, and had been run dry for about a month (found a really leaky seal)
