Whining Bosch pump
owcarps13
Car: 180sx
Hi to all,
I have a problem with Bosch 040 pump.
Setup:
Sr20det, ecu EMU, 370ccm, t28 ball bearing.
I replaced fuel pump (previous died) for Bosch 040. I put full tank and drive maybe 200miles and it start to whine like previous one. Right now I got 3/4 of fuel. After 10 minutes of driving whining becomes louder and car goes up to 3000rpm, after another 5 minutes 2000rpm is not possible so going from second to third gear is a dream. But when I let it rest for 5 min or so it starts to work propperly, but after 5 minutes whining and no power starts again.
Any ideas what is wrong? What to check?
centralcoaster33
Car: 1997 Nissan 240SX #5
Just off the top of my head... You just worked on it, so double check your work and consider using the FSM while you're checking (look here: http://www.nicoclub.com/nissan-service-manuals). Next, fuel pressure matters, so get a gauge and check the fuel pressure before the FPR and on the rail. I assume you have a relatively new fuel filter on there. If not check that to see if it got clogged somehow or just go and replace it.
Welcome to NICO Club!
