whining/bearing noise in the engine?????
98frontier_islander
Car: 240sx 97
i changed my ground from my battery to my block and test drove it.ran better than before.i was in second so decided to take it to 3500 rpm then shift quickly and stomp it again to 3500 rpm,then out it in neutral and roll to the stop light.
now i notice a whining noise around the intake manifold area and as i rev the motor it gets higher and as the whine slow down with the rpm i can hear a bearing spinning.
not to mention i smell a burning/melting smell coming from the back of the intake manifold too.
i checked my belts,pulleys,checked the obII's diagnostic codes,nothing.out of the 4 years i had my truck i never encountered this before,please help this is my daily driver.
1998 nissan frontier 4 cyl ka24de 2wd regular cab standard transmission.
oddjobbb
Car: 2006 350Z Roadster and a 1995 nissan pickup XE 4X4
water pump bearing?
98frontier_islander
Car: 240sx 97
that was one of the things i thought it was but the noise comes from the rear in the engine?would a frozen input bearing cause the whining and burning smell.........input shaft slides along the frozen bearing and burns cause of friction from metal on metal contact?
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
Sounds more like an idler pulley, and the smell is probably a smoking belt.
NM50
Car: 94 D21,98 03 hummer H2,66 311 CA18ET ROADSTER,94GEO METRO pimp mobile
Does the noise change whenever the clutch is pushed in?
