whining and grinding
spyin.inu
Car: 89' 240sx hatch, 90' 240sx hatch & 96' 240sx SE
well i got my car from the shopi bent my lower control arm and brace(but its fixed)
well i had no problems before handnow the pulley on the water pump whines and when i shift into 3rd gear ranging from 3000+ it slightly grinds but if i shift lower it doesnt
idk if my 3rd gear is slipping or what?will the whining stop?
90 240 ka24eno transmission modsnew water pump(about 6+ months old)
navysnail
a car as old as you may have problems developing with the 3rd gear synchro, it is fairly common. as for the water pump, replace the belt and check to ensure it has proper tension
spyin.inu
navysnail wrote:a car as old as you may have problems developing with the 3rd gear synchro, it is fairly common. as for the water pump, replace the belt and check to ensure it has proper tension
yeah it seems like my 1st gear is starting to mess up tooi can be at a dead stop and when i shift to 1st to go, it sometimes grinds someno other gear does it beside 3rd
would this mean i need to get a new transmission or some work done?
