Whiney noise at start up
infiniti007
Car: 2003 m45
I have been hear a strange whiney noise only at start up over the last 3 weeks. The noise only lasts 25 seconds and stops completely after the car is warmed up. I though it was due to power steering fluid being low, but I filled it up and also filled up cooling fan liquid reservoir. The power steering pump waqs recently replaced by Infinity. Is is possible that waterpump is going bad .. Or can it be a belt tenionier
splix
Car: 08 M45X
Idler pulley, bearings are going.
infiniti007
Car: 2003 m45
Thanks for reply.. I just changed my drive belts 10,000 miles ago you think I would need to change the belts again?
MOWellsinVA
Car: 2007 Infiniti M45 Sport (Obsidian Black w/ Graphite interior)
Belts are probably fine. The sound you describe is exactly what a idler pulley sounds like when the bearings are going bad.
Gilded_Splinters
Car: 2003 M45
It probably is your idler pulley, but here's how you can be sure:
First, identify the idler pulley. It might be shown in the belt routing diagram in the engine compartment.
Start the car cold and while it's whining, spray the bearing area of the pulley with silicone spray. Avoid spray oils as they will make belts slip. If it momentarily quiets down, that's it. If not, try a spritz on other rotating parts.
infiniti007
Car: 2003 m45
Yep it's the idler pulley...just checked with dealer idler pully cost about 190.00 ...Autozone doesn't carry idler pulley...on Ebay it costs 45.00... has anyone used Ebay parts on their car?
FNAWSM
Car: Diamond Graphite '06 M45
I have that same "whiney sound" every morning when I start up my day... turns out its my wife :frown:
splix
Car: 08 M45X
damn I'm good haha
Got a link to the ebay listing? $190 for an idler is rough.
TXT
Car: 2006 M45 Sport
FNAWSM wrote:I have that same "whiney sound" every morning when I start up my day... turns out its my wife :frown:
HA wasn't expecting that post to end that way lol!
InfinM3506
Car: 06 Infiniti M35 Luxury Edition, Journey Package, Tech Package, Burnt Orange Leather. Eibach Pro Springs, 20" Vossen CV3 20x9 255/30/20. 20X10.5 285/25/20. 08 Front Infiniti Sport Changeout.
http://www.z1motorsports.com/350_g35/pr ... ts_id=5640
Hey everyone would this work instead of paying for a new one? We already have two Idler Pulleys, why not get rid of one. Has anyone done this on here?
The Bodyguard
Car: 08 Infiniiti M35 black loaded custom VIPDOUT
08 Infiniiti G35 S sold 92k miles
08 Infiniiti M45 S sold 78k miles
07 Infiniiti M35 traded 53k miles
95 Infiniiti J30 sold 155k miles
Location: Cypress, TX (Houston) o.g. from southern cali (North Hollywood)!!
I'm just throwing this out there although you did mention the dealer already said they found the problem... Pay close attention to the winding noise and place your ear on it!!! I'm thinking your headlight may be the cause!! My passenger side headlight did that winding noise from time to time until one day it wouldn't go off... if you touch around the headlight unit where the light bulb plugs in and the afs motor is you can actually feel some vibration where the motor tends to go out and is constantly trying to move the adaptive headlight...
Just a thought so you can look into that since that's much more expensive to replace!! $1250 each headlight!!! :gotme
atlM35
The only whine that I want to hear is a supercharger.
