madbouncy »
https://forums.nicoclub.com/madbouncy-u15966.html
Wed Jan 12, 2005 4:08 pm
I'll try and do some of that stuff today. I'll make a grounding spot for the amp on the chassis, that'll also take like a foot of wire off the grounding cable. So far all I've noticed is that if I put the headunit to 0 volume, I still get the noise. However, if I unplug the rca cables from the amp, the noise is gone. So I dont' know if it's just cutting power to the speakers and that's why it's gone or if it's still powering them but the noise is in the rca cables. Also, it's alot worse ni the front speakers. I put the filter on for the amp, I had to set it like twice as low to get rid of the noise in the frotn speakers as the back speakers. So my guess is, whatever noise is happening is because of the path along the rca lines. I'll try and get that noise filter tomorrow if I can afford it. I'm working on a grounding kit for the engine. There's a stripped hole in the valve cover and then the tap broke in half in that hole, so that was put on hold. I can probably finish the rest of the kit and just leave that one wire out till I fix that though.
This is sort of how it goes. The amp and battery are in the trunk. I ran the rca cables and two speaker cables along side the drivers side of the car. It starts behind the head unit then goes under the steering wheel, then down under the carpet, then it comes up from under the carpet at the back seat, goe under the backseat and then up into the trunk. The amp is mounted to the back of the seat (it's a coupe.) I figure it's a problem along there because then the front speakers would have to run past whatever is causing the noise twice, where as the rear speakers would only go past once. Does anybody know of something around there that could cause a big problem? Also, there was a dc to dc convertor or something on the headunit, I put it as far away from the wires as I could but it was only like 3 inches away. Has anybody ever had that cause noise problems? Sorry for such a long post, thank for the help again though.
