srpowered240sx »
https://forums.nicoclub.com/srpowered240sx-u30143.html
Wed Jan 25, 2006 7:49 am
power steering disconected like, the lines are all off, or the belt is off the p/s pump, or there is no pump all-together? id take a little belt dressing, or even wd40 and spray the inside of the belts to rule them out. if the belt is dry and cracked it will make a humming/whining noise, the wd 40 will lube it enough to stop the noise momentarily. i disregarded that noise for a month or so, finally sprayed them to check, then broke down and changed them and no more noise.
