While I'm at it...
s13conv
Car: '86 GT-S Coupe
I'm going to be putting a manual transmission in place of my auto [89 240sx]. What should I replace while I'm at it?
So far I have:
Clutch TOBpilot bushingTransmission extension housing seal
Should I replace the pinion seal in the rear?
s13conv
Car: '86 GT-S Coupe
Also, it the auto transmission mount the same as the manual?
s13conv
Car: '86 GT-S Coupe
NeedCAforS13
Car: CA swapped S13 coupe
you need a manual transmission crossmember and mount as well as the clutch/brake pedals and lines, but I'm assuming you already know this:)
if not check the FAQ: http://www.240sx.org/links/ins...p.htm
Sean
s13conv
Car: '86 GT-S Coupe
Thanks. Just making sure before I buy one. I have most of the parts, however, I keep finding more that I need. I drilled the hole for the master cylinder today! I hope to have it together and moving (for the first time in 3+ years) in two weeks.
