While I have it pulled...
Z32Only
Car: 1993 Nissan 300zx TT
1997 Eagle Talon TSi
The motor is out and have a few things planned, any advice on what else I should do while I have it out will be appreciated, I don't wanna pull the damn thing again :biggrin:
upgraded idler studs, valve cover, rear main, oil pan, cam seals, replace rubber half moons, oil filter tree gasket and o-ring, Replace 02s, replace knock sensor, replace knock harness, silicone hoses, water pump, debating on lightweight pulleys, downpipes, rebuilding turbos and timing belt of course since I'm not 100% when it was done last..
Delete EGR, AIV, water lines, carbon canister.
Look good? Anything else?
Ziggy1621
Car: '90 Z32 TT (Shibui)
'90 Z32 2+0 NA
'68 311 Roadster
2004 Rx330
2011 BMW 550i (TT)
When you say rebuilding turbos, you really should be saying replacing chras ;) your list looks good. I would also do the pcv relocate, that coupled with the water reroute makes a plenum pull a 15 min job.
How many miles on the motor? Have you done a compression test on all cylinders?
