Which z32 wiring diagram is right?
jdmimms
this one
http://www.sxoc.com/site/static/z32afm.php
or this one
By white do they mean black w/ white strip
http://bagpuss.swan.ac.uk/200s...g.jpg
also is it possible to have it hooked up wrong and still be reading %'s on the safc2?
thanks,
Josh
paul_s13
I used the first one and its fine, I'm using the stock ecu and didn't have probs when I remappedit for the big afm.
jdmimms
Why do I have to hook up an outside power source when I already have 12v+ on pin2 from the ca wires?
jdmimms
Sorry my above post made no sense its just that my wiring is very different
so you remapped your ecu for the z32 maf and wired it up like his and it works great?
paul_s13
jdmimms wrote:so you remapped your ecu for the z32 maf and wired it up like his and it works great?
Yes.
jdmimms
What is the signal wire on the ca side, green with yellow stripe? Just make sure I'm viewing at the right side.
drift-racing
Car: fast nissans and jackedup toyotas
So josh, how did the wiring turn out. Just wanted to know because i am going to be installing a z32 maf on my ca18det.
Thanks, Kirt
paul_s13
Sorry for not replying, I've been a bit busy, I have to do a bit of tidying up of the engine bay because I've sold the car, I'll check the wiring tommorow.
NeedCAforS13
Car: CA swapped S13 coupe
paul_s13 wrote:because I've sold the car
noooooooooooooooooooooooooo!!!!:(
Paul your car rocked dude! Why'd you sell it?
Sean
paul_s13
NeedCAforS13 wrote:noooooooooooooooooooooooooo!!!!:(
Sean
It has financially crippled me, I can't afford the running costs anymore, also I want to get my own place so it has to go.
I think I did well getting £4800 (about $7,853) for a 10 year old Datsun. :D
drift-racing
Hey paul, I was wondering what you came up with on the z32 wiring. The more detail the better. Like witch way you looked at the plug.
Thanks, kirt
paul_s13
drift-racing wrote:Hey paul, I was wondering what you came up with on the z32 wiring. The more detail the better. Like witch way you looked at the plug.
Thanks, kirt
Oopps sorry I forget :oface i'll look tonight.
