Which year featured the improved oil cooling?
Nissan 350z / Nissan 370z general community discussion forum
PalmerWMD
Car: 2004 350Z
I recall the aerly Z ran the oil hot..
Other than reformulating an especially tough 5w-30 NIssan improved the oil cooling.
Anyone know which MY has that imrpoved cooling?
Bubba1
Car: 2003 Nissan 350z
2024 Honda HR-V
2008 Toyota Corolla S
2001 Toyota Avalon XLS
I was under the impression the 350Z's that experienced abnormally high oil temps were mostly forced induction conversions driven under extended extreme conditions, like long track/drift sessions under full boost. IF your planning to flog your Z for long sessions, adding an oil cooler is recommended. The majority of the stock normally aspirated versions driven on the street should be fine as is. If you're worried about oil temps, adding a oil temp gauge should ease the concern. I could be wrong but I think it was 2006 is when Nissan added an oil temp sensor to the 350z that would trigger a self preservation mode if oil temps got beyond a certain point. Enjoy
PalmerWMD
Car: 2004 350Z
Thanks..:)
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
My base '14 370 will see oil temps creep up in the 240 range on mildly spirited summer drives here in AZ. Synthetic oils are a must when temps get that warm.
sx moneypit
Car: 2010 Nissan 370Z
1986 Toyota MR2
2012 was the first year that had a factory oil cooler.It is sandwiched between the filter and the block.
PalmerWMD
Car: 2004 350Z
sx moneypit wrote:
Thu Feb 06, 2020 12:44 pm
Thanks :mike !!
sx moneypit
1986 Toyota MR2
You're welcome!
Return to “350z / 370z Discussion”
