Which Wheels, What Color?? POLL
crzycav86
Car: 93 Nissan 240SX KAT
ChunkiDori probably meant for you to use a 25mm bolt on spacer, which won't require longer studs, because the there are separate studs built into the spacer.
MECPInstaller
Car: installing stereo systems and minor performance upgrades
how do those work? i mean if they have the studs built into them isn't the existing studs still going to stick through them? not getting the concept.
BuudWeizErr
no, because most wheels have backpads ( i think they're called?) with room for studs to stick out. Like on the mounting face, in between where the studs come through, there will be a blank spot where a stud and lugnut could happily sit and not touch anything. I wish I had a picture so I could show you what i'm talking about.
your other option would be to grind down the stud slightly after you have the spacer bolted on.But with a 25mm spacer, it won't stick out all that far anyways.
accel junky
Those are bad as crap. I had some similar looking rims on my '97 lude.
chmercer
why does this thread keep comming to the top? i have no idea how it got back to the first page.. (and im not talking about my bump) will somone erase this or whatever
nismofly
Car: 89 Nissan 240SX Hatch
i think if anyone votes in the poll it counts as a bump
in other words the thread probably will need to be closed to keep people from voting, and hence bumping
Fenvy
Car: 2005 350Z Base 6MT
honda wheels
chmercer
gah! somone please lock this or somthing? this crap is a year old
