Which Weber carb for a '85 Nissan 720?
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
bendavis1
Car: 1985 Nissan 720 King Cab 4x4
I have a 1985 720 4x4 and have had some carb issues for a while with it (idle, choke, etc.). I have been very interested in swapping to a weber carb for a couple years and am finally going to do it. Im curious as to which of the webers would be best for a decent power gain without drastic fuel economy loss. I have heard the 34/34 is a good choice... what about the 38? Or the newer 36/36 syncro? Let me know! Thanks
Nissan_Boy85
Car: 85 Nissan 720
I know a common choice for most datsuns are the 32/36. I run one and it hasn't failed me yet. Can't say the same for my old stocker.
2kredz3
Car: 1984 Nissan 720
just ordered the 34/34 on webers site it shows the ones that are acceptable for the z24 motor
http://www.webercarbsdirect.co...7.htm
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
For the best fuel economy use the 32/36. It gives decent power and maintains economy. The 34/34 and the 38 uses more fuel but gives a drastic improvment in power, but with such increases the economy goes out the window. Had a 32/36 on a NAP Z20 in a 1984 Mitsubishi Galant supersaloon, and my uncle has one on his 1983 720. The fuel economy is fantastic!
2kredz3
34/34 was running great, then blew head gasket.
i dont think the carb caused it more a result of my driving style after the install of the new carb
moredunes720
Car: 1985 nissan 720 4x4
so, after the carb is installed, what happens with my 652 vacuum hoses and all the goofy wiring? Lol the vacuum hoses and emission controls were sadistic on these old trucks....
flinterman2000
I live in the Caribbean so smog controls are not an issue. I blanked all the egr and isolated the wiring which was not necessary. Sorry I cannot help more.
PEZi
basically the only vac lines you need are the distributor advance and the EEC canister ones
you can even get rid of the EEC canister ones if you come up with some other way preventing vapor lock in the tank... i'm in the process of figuring this one out
as far as the wiring... start cutting wires with the truck running and see which ones affect it... its more of a 'test and play' thing
Return to “Datsun 720”
