twinturbozxtacy »
https://forums.nicoclub.com/twinturbozxtacy-u212920.html
Sat Jun 29, 2013 5:54 pm
no boost, turbos spool fine with tb pipes disconnected. did a boost leak, everything is tight and leak free. new plugs ohmes all the coils and injectors, new ptu. after a long search i found it to be my turbos spooling too fast and not getting enough air and what is happening is a compressor "stall" meaning it sucks the air in so fast that there becomes, for lack of a better word, slack in between the compressor wheel and incoming air. Once this happens the compressor is rendered useless and then once the lagging inake air "catches" back up the process repeats... at least thats how it came across to me.
-A compressor stall is a situation of abnormal airflow resulting from a stall of the aerofoils within the compressor of a jet engine. Stall is found in dynamic compressors, particularly axial compressors, as used in jet engines and turbochargers for reciprocating engines.
Compressor stalls result in a loss of compressor performance, which can vary in severity from a momentary engine power drop (occurring so quickly it is barely registered on engine instruments) to a complete loss of compression (compressor surge) necessitating a reduction in the fuel flow to the engine.
Modern compressors are carefully designed and controlled to avoid or limit stall within an engine's operating range. Stall was a common problem on early jet engines with simple aerodynamics and manual or mechanical fuel control units, but has been virtually eliminated by better design and the use of hydromechanical and electronic control systems such as Full Authority Digital Engine Controls.
