which way do they go?
240wootie
Car: 1989 rb20 coupe, 2002 WRX
i'm trying to figure out how the coolant lines on the back of my rb20 run. i'm assuming the bigger lines are the heater hoses, but where do the little brass lines off the turbo hook up? also the one you see clamped shut on the heater hose. [IMG][/IMG]
thanks!
240wootie
anybody?
Carl H
remove that yellow cap off of the top hard line going to the turbo and connect the rubber line comming off of the intake manifold to that.
240wootie
k.. i took some more pix. maybey this will help more. the two going into one my hand is holding? also the hardline off the turbo y's as well... the larger one on the block? another heater line? thanx carl!!
Modified by 240wootie at 7:48 PM 2/26/2007
240wootie
bump for some help?
tintdude69
Car: 90 Sr20 hatch..
240wootie
dude, ur my hero! i've been searching for a rear pix of an rb20 like that.
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
Just as posted above, remove that yellow cap and plumb that line that your thumb was touching to it.
NISMO_RB25
Car: 1992 240SX with RB25DET, 1987 RX-7 TII
It is kind of odd that those lines are capped. Is the turbo stock? Just wondering if someone changed the turbo out to oil cooled only, or possibly decided to just use oil cooling on the stock turbo.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
You can either take the yellow caps off and reattach the water cooling lines to the turbo (assuming they are still there and connected to the turbo) or run the setup the way it is and figure out how it was plumbed up. I'm assuming nissan had water-cooling to add some reliability/longevity to the stock turbo setup??
Carl H
most people dont let the cars idle down after driving so when you shut them down no oil gets to the center section to cool it down some, but when the car is shut down water still circulates for a little bit.
Sil240
Car: Nissan S13 "The One Cam Wonder"
Hey Check for either a leaky 6th Fuel injector.Your either going to need new seal's and bushings or your going to need a new Intake manifold gasket.
I'm sure it'll be a lot easier to change it outside of the car. I can only imagine how much of a PITA it is to pull off and re-install that ITM.
240wootie
Sil240 wrote:Hey Check for either a leaky 6th Fuel injector.Your either going to need new seal's and bushings or your going to need a new Intake manifold gasket.
umm.... k...? just advice or did it have something to do with my thread?
*edit* i see what you're pointing out, thanks!
Modified by 240wootie at 4:10 PM 2/27/2007
Sil240
Yeah looks more like the gasket.Your intake manifold might have some nasty ish in there too, so you should clean that bad boy out as well.
I know mine had pools of oil and caked on shyt in there. While you have it all apart clean out your AAC/IACV also.My friend's was stuck open because it was so dirty.
