180fan wrote:dude the things solid in the rear. you don't need em, although there's that one by obx that looks like the DC sports ones you see on the hondas all the time, but that doesn't do jack.
btw don't bother looking at the cusco one that bolts up into the tension rod bolt area. it's like 80 bucks but doesn't do jack but add that little bit of blue in there. You're alot better off with the Nismo unit if you're looking for something to brace the bottom
Loveless wrote:what about for s13? do you think I need one for either from or rear?
Exar-Kun wrote:Yeah, you can still use the power brace..you just cant use the sustec or cusco tension braces with the nismo power brace because they take up the same spot.
I have the tanabe underbrace, I like it.-chet
