Midnight Tech wrote:There's a good chance you're gonna need a Neapco 1-0430 to fit your Hardbody - is yours the one with the smaller, staked-in joints?
First off, let me say I really appreciate your reply. After reading your reply this morning, before work, I decided to go get a 1-0430 and try it. I showed the part # you gave me to the clerk at Advance, and he determined that it was an '89 joint, so I figured that I might be on to something with the 0430 joint. The cap of the 1-0430 just fell through the holes in the yoke and driveshaft, but the 0029 joint that the computer called for, was far too big. I went behind the counter to look for myself, and found one similar to the one that came out of the truck, which was a 0105 Advance PDQ joint. I did have to message the holes a little to make it fit, with a stone bit and die grinder, but it did work. Maybe as much as .005 . It is in the truck and is tight as it is supposed to be. So I guess I will always have one different joint in the truck.
I would still love to know what the correct part # for the joints that are in the truck though. Once again, I do really appreciate the help.
