SuperHatch wrote:
In my experience with BB vrs. Std. Bearing turbos (which is quite substantial), the BB turbos aid very little in spool up. Where they really shine is in the transient areas.
Example...
Standard bearing GT30 might get full boost at 3600RPM in third gear on a 2.0L Mitsu. A GT30R might get full boost at 3500-3550 under the same conditions.
Is that with the same turbine housing though? I think generally people tend to run larger turbine housings with the BB unit as they can get the same spool with better top end capability. I haven't personally got to mess with BB turbos but that was the impression I was under.
Quote »Do you have any feedback on the GT30R (other than it being a bit pricier ball-bearing turbo)?[/quote]GT3071R:
@ 1.4 PR/5.88 PSI will surge at:60% - ~3,300 RPM70% - ~2,800 RPM80% - ~2,500 RPM90% - ~2,200 RPM
Choke point: ~31.5 lb/min
@ 1.68 PR/10 PSI will surge at:60% - ~3,800 RPM70% - ~3,300 RPM80% - ~2,900 RPM90% - ~2,550 RPM
Choke point: ~38 lb/min
GT3076R:
@ 1.4 PR/5.88 PSI will surge at:60% - ~3,900 RPM70% - ~3,350 RPM80% - ~2,900 RPM90% - ~2,600 RPM
Choke point: ~36.5 lb/min
@ 1.68 PR/10 PSI will surge at:60% - ~4,350 RPM70% - ~3,700 RPM80% - ~3,300 RPM90% - ~2,900 RPM
Choke point: ~44 lb/min
VH45DE lb/min at 1.4 PR/5.88 PSI at 7,200 RPM:60% VE - 16.57 lb/min70% VE - 19.33 lb/min80% VE - 22.09 lb/min90% VE - 24.85 lb/min
VH45DE lb/min at 1.68 PR/10 PSI at 7,200 RPM:60% VE - 19.89 lb/min70% VE - 23.20 lb/min80% VE - 26.51 lb/min90% VE - 29.83 lb/min
The GT3076R used to be my preferred turbo for the VH45... but looking at it now I think it would be a bad choice for me since I'm wanting more low end power than high end essentially. The 3076 could potentially support over 1000 bhp... if that's what you're looking for they should be excellent for that. (though... at that point it might not be a bad idea to step up to the GT3582 for a little better efficiency in the higher range).
(Note: Just in case anyone is curious... when I say "choke" I'm basically talking about the end of the compressor map, the furthest point to the right. The turbo is still technically providing boost... its just so inefficient that they don't plot any further (usually 60% is the cutoff point. For instance, the 20G's cutoff is actually 65% so technically you could actually push it a bit further for lower efficiencies... though I wouldn't personally recommend it as it would be putting out a lot of heat).
Correction to my info above - I don't know why... but for some reason I put VE (volumetric efficiency) when I was talking about turbo efficiency when it should be adiabatic efficiency (heat efficiency). I'll correct that asap.
More on the VE stuff... just figured I'd throw this thought out too.
All you're essentially doing with boost is increasing the VE (of course, we're cramming more air into the cylinder). Say for instance you're pushing 12 PSI or a 1.82 PR at 6,000 RPM and our airflow is 345.6 CFM at a standard engine VE of 80%. To get the same airflow NA would take a VE of 231%
Now, I have to again stress that all of these numbers are to give you a simple idea of what the turbo could potentially do. The likelihood of it performing by these numbers is slim since there are so many other variables like air temp, pressure (altitude), etc. etc. etc. Even the volumetric efficiency calculation is a bit difficult to do considering the ports are likely to act completely different under boost than they are NA among other things. The best thing to do is to find the turbo that meets the majority of your needs basing off of this info and going from there. Luckily it will at least perform correctly unlikely blindly throwing on a huge turbo or a small turbo where one takes forever to spool and the other chokes quickly... this info just gets you in the right area.
