Which turbo??
GoofyATX240
I know this might sound stupid heh. But I recently fell in love with autocrossing, but at the same time if I run into someone on the street to run or drag racing which turbo and specs and all would be suitable? I had a turbo in mind, but now I dont think it would be all that great for auto-x. I would need something that could get me in 300hp range and still be able to auto x with it. I swear I always change my mind on the turbo I wanna go with heh. And yes I understand a/r and all that mess. Thanks in advance.
Nathan
Definitely a ball bearing unit! How much are you looking to spend?
GoofyATX240
Just a little over 1k. Since ill be saving for some time now. so about 1500 is the most im willing to spend. of course it wont be this month that I buy it hehe.
slw240sx
Car: 1990 Ca18det 240sx Hatch
gt2530 or 2540
Nathan
good luck affording it...unless you mean the garret one, which one, the HKS or the Garret Jon?
Oneor1
Car: cars, music, hockey
hmmm... any good turbo's out there for the CA for around 500 or so?
Nathan
Well...I was actually thinking of the Super 16G from here: http://www.turbosystem.com/auto/sales/sales.htm just have a T3 flange welded onto your stock manifold. Best part is...only 600 bucks an a warranty!! :D
GoofyATX240
Nathan wrote:good luck affording it...unless you mean the garret one, which one, the HKS or the Garret Jon?
Im hoping he means the garret one. I might have to check out that 16G hehe. When does that turbo spool and all and whats the max power for it?
Nathan
I think the 16G would be pretty laggy...like boost at around 3500-4000 maybe.
Oneor1
heard people had some bad luck w/ the welding of flanges on the stock manifold.
also have u guys checked out the turbos on JGStools.com??
Nathan
If you weld it on there good enough...just make sure that its like one solid weld :D
Oneor1
cool cuz jgs sells all different types of flanges too
GoofyATX240
Damn. Now im contemplating still how much hp can it put out anyways?
Nathan
Well GENIUS, why dont you stop being so DUMB and READ you GOOFY FOOL!!!! It says 400hp but I think that'd be pushing it, figure on not running more than about 17psi on it and making around 300-320hp (I'm conservative) for it to live a long and healthy life :). If it was me I'd set it at about 15psi and forget about it. Dont forget you'll need to do something about fueling at those levels: upgraded injectors and at least an safc.
GoofyATX240
Hmmm well when I read that ir didnt even say a hp number your reading the 1k$ one ehhe. Unless I went to the wrong part lmao.. Whats everyone think of the turbo at the bottom of this page http://www.jgstools.com/turbo/t3t04.html. I know ill need fuel u damn seducing person ahha.
Nathan
hey, screw you! Can't we just put the seducing thing behind us??? haha...and that turbo is only 600 bucks, once again...another case of you NOT READING. tool
slw240sx
im talkin a garrett , HKS way over priced, i found mine nearly new for 700$. i think im goin t3 next winter
McAdam
Car: I like cars and my motorcycle. boats are fun too
go to this page and click on 1989 - 1990 VNT turbo. uses standard T25 cold parts and seals. so, you can get a "big T28 upgrade done to it. found this
Quote »SUPER 60 T2[/quote] Quote »This upgrade is a direct boltin for the T2 equipped 90-91 VNT turbo applications. The turbine section of the VNT turbo is matched to a larger 500cfm T28 compressor wheel and equipped with the 360 degree severe duty thrust bearing system for added durability at high boost pressure. The pictures below show the factory compressor wheel dwarfed in the modified compressor housing and also the complete Super 60 T2 VNT unit[/quote] Quote »$695.00 exchange with good core[/quote]
from this page dodge crap
hope this is some help
dan240
Car: killing stealth R/T and camaros
precision turbos SC61precisionte.com
