hannibal »
https://forums.nicoclub.com/hannibal-u1252.html
Fri Jun 24, 2005 5:35 am
Smaller turbo = faster spoolSmaller turbo = less top end performance
Its a compromise. You can use a huge turbo that wont boost until 5000rpm. Or you can use a tiny turbo that boosts from 2000rpm, but drops off above 5000rpm.
Ball bearings are great for quick spool. Thats why the BB Garrett GT turbos cost so much. Theyre the best of both worlds.
I guess the T3 mentioned above would have more lag than a BB T28. SR guys hit 250whp with the stock turbo, so the turbo is capable of it. If youre going for 250whp with quick spool, I dont think you can beat the T28 with ball bearings. The T3 might do better up top, but would have slightly more lag. Either turbo is going to be past its max efficiency at 6000+rpm. Its a tough call
mendoza, if you eventually want 350whp, I'd definitely go with a T3/T4.
