Which transmission mount for an rb20 swap into s13 if using r32 xmember??? (Searched)
SuicidnS13
Car: SC300 2jz, 93 Vert (RB), AcuraTL
After searching and going through over 12 pages of results I still dont have a clear answer as to which transmission mount to use on a 240sx swap when using the r32 x member. Will the ka24 transmission mount work on the rb20 transmission? Or do I need to find an rb20 transmission mount to mount into my 240sx?
placham
Car: 1992 Geo Prizm (4AFE)---Gone
1990 Nissan 240sx Coupe (RB20DET powered),
1994 Toyota Celica GT (3SGTE swapped), 1995 Nissan 240sx KA24DE,
2011 Nissan Sentra SER Spec-V
Think S13 and Rb20 R32 are the same(I never compared them), but I used the one that came with my trans, R32 Rb20 trans mount/member bolted on with no modifications, (I'm also running r32 front(engine) crossmember with R32 engine mounts) Think their interchangeable, since your going to use your stock drive shaft and it's a perfect fit for Rb20 on S13.
pepegurr
Car: 89 coupe w/ rb20 swap - RIP but making a comeback
86 Porsche 944
92 FZR400 - Track Slut
95 240sx-se - Newest member of the family- DD
you can just use your stock ka24 trans mount.
yotik
Car: 240sx Hatch
my ka24e crossmember is not fitting...
Carl H
gotta use the one that came with the trans...i think it is the 'c' mount.i have seen 'a' and 'b' version...they are manual and auto.the letter is stamped on the trans xmember, its been a long time since i had my engine out so i dont remember exactly.
yotik
Car: 240sx Hatch
my swap didnt come with the rb transmission xmember this sucks. always sumthin
