which to turbo?????????
dutman94hb
Car: 94 hardbody
Which motor would be the best one to go with when adding a turbo and intercooler? The ka24de or the ka24e(which i have ka24e)????????
drifts14x
Car: Cars, Motorcycles, Drifting
KA's are relatively close in the difficulty of turbo and intercooler install. E's are more easy because they have only one cam, less tuning capability, but easier none the less. I have a DE, it's just a matter of more timing to do. It's really up to you.
WDRacing
There are more kits for the DE
Structure240sx
having one cams has nothing to do with putting a turbo on. install one cam could be a little easier than installing two but thats about it. the DE has more aftermarket as of right now making it slightly "easier" to turbo.
personally im big on putting a turbo on what you already have
2_Liter_Turbo
Car: _________________
'96 S14 Coupe: SR20VET
'90 R32 TH1 GTR: RB26DETT
'92 S13 Fastback: SR20DET
'11 V36 Sedan: VQ25HR
'06 GMT800 2500HD: LBZ Duramax
I believe the SOHC motor does not have oil squirters, while the DOHC does. This will turn up the whole reliability issue. It is more practical to turbo the DOHC becasue it can handle the added stress better, than the SOHC.
TheOne
Car: 93 240sx FB
you'll probably get more power from the DOHC anywayz, cause there's more intake & exhaust flow compared to a SOHC.
Structure240sx
if your motor is strong and runs good turbo that. enough said.
dutman94hb
Car: 94 hardbody
thanx for the feed back guys. I got one more question for ya how hard is it to swap the DE head on to my E motor??????
deathplaza
Car: my dads nissan stanza se 92 till i get my own sx
apparently glacier985 still hasn't completed his sohc to dohc swap and after reading it many times it became apparent that its pretty damn hard.
dutman94hb
Car: 94 hardbody
Well i was told that a donc head off a 98 frontier was the easiest way to go especially if i could get the intake as well ..............But i duno I have done a couple of head jobs on hardbody's and they got more simpler each time
crzycav86
Car: 93 Nissan 240SX KAT
dutman94hb wrote:Well i was told that a donc head off a 98 frontier was the easiest way to go especially if i could get the intake as well ..............But i duno I have done a couple of head jobs on hardbody's and they got more simpler each time
So do you want turbo, or do you want to swap your head to dohc?..remember that the head swap raises your compression ratio to over 11:1, which is incompatible with boost. ...or you can have both with low compression pistons.
dutman94hb
Car: 94 hardbody
Thats the idea get the DOHC advantages whike lowering the compression for a turbo, Thats my dream anyways
