Which tire size would be better?
erick.s
Car: 2008 Altima 3.5SE Coupe
I'm going to be picking up a set of 18s soon and I've been looking into tire options. The stock size (235/45) seems to be an odd one and I'm not seeing many choices that I like. There are many more choices if I change to 225/45 or 245/45. I've done the calculations and a 225 will be 1.3% too fast while a 245 will be 1.4% too slow. I would think that being slightly too slow would be better fo the odometer, plus I'd like to have the greater contact patch. Is my thinking right or am I off base?
marlin29311
Car: 2008 Infiniti G35x
What brands are you looking at? I find a lot of tires in the 235/45 size...
Are you looking for summer or all season?
erick.s
I want to buy my wheels from discount tire direct, so I'm kinda locked in to what they have in the 235 size. Mounting and balancing are free so if I bought wheels and tires from different vendors and took them someplace locally for mounting I'd end up paying more. They only have 5 tire choices and two of them are Kumhos. If I go to the 245s I can get the Dunlop SP Sport Maxx which is a really good tire and there's an $80 mail in rebate on them right now.
The Altima is my summer car (I have a Jetta Wolfsburg with snow tires for the winter) so I wanted to go with either a summer only or a very high performance all season. In the fall I'll swap the stockers back on just in case I need to run out over the winter in the car.
marlin29311
http://www.discounttiredirect....s=235
Best A/S tire you can buy.
EDIT: I see they are out of stock....
Why don't you try looking around at other sites like TireRack or something?
desertdragon
Car: 2008 Altima coupe 3.5 SE with CVT Winter Frost
erick.s wrote:I'm going to be picking up a set of 18s soon and I've been looking into tire options. The stock size (235/45) seems to be an odd one and I'm not seeing many choices that I like. There are many more choices if I change to 225/45 or 245/45. I've done the calculations and a 225 will be 1.3% too fast while a 245 will be 1.4% too slow. I would think that being slightly too slow would be better fo the odometer, plus I'd like to have the greater contact patch. Is my thinking right or am I off base?
It seems like you did your home work. Yes, what you have said is correct.It's all personal preference, using your logic, I would go with 245/45, this tire will give you a softer ride (more rubber).
I used to have 235/45 and I changed to 245/45 and I am happy with them.
