Which Throttle Cable Do I Use for my S13 SR?
9095240SXDUCK
Car: 240SXs
Hi I try to search on this but can't find anything.
Well I notice the reason why my 90 S13 with a SR20DET Red Top can't idie is because my Throttle cable is too short! So to all the people that has a S13 With a SR20DET please tell me which Throttle Cable should I use?
Do I need a SR or KA24DE or KA24E. I think the one in my car right now is the Org KA24E!!
Thanks!
Every Info Counts!
Thanks Again
9095240SXDUCK
Car: 240SXs
Come On someone has to know the right answer to this.
I know it sound stupid! But when you don't know, you don't know so. Please Help me out!
f150intally
i used my sohc throttle cable just fine. it was a tight fit but it worked well. how are you routing it?
robbbby
Switch to the cable from a 91+. It is much longer and easier to work with. Not to mention the bonus of not running the throttle cable over top the valve cover.
808DRFTR
Car: 89 240sx KA24DE Swap
91 240sx SR20DET Swap
02 Sentra SER Spec V
01 QX4 4x4 Lifted
01 I30
11 M56 Sport
robbbby wrote:Switch to the cable from a 91+. It is much longer and easier to work with. Not to mention the bonus of not running the throttle cable over top the valve cover.
Mine didn't work and it was from a 91, used my friends SOHC one and it worked fine just goes over the valve cover a little like you said. I think you could modify the line from the 91+ a little and it should be fine, I was just lazy
9095240SXDUCK
Car: 240SXs
Ok here is my ThingRight now it is running on top of the Valve Cover
The problem that I have is that the car does not Idal right but If I move the Throttle Cable alittle over the top of the Valve cover (Because it is not long enought to go around the Cover) it will idel alot better and stay good until I move it like driveing it/push the Gas pedal!
But here is another funny part is that, it seem to run alot better when I have drive it for a mile or 2!
I don't is this True or Not but I have hear from people saying that maybe a G20 or older SE-R Throttle Cable Holder will fix it!
9095240SXDUCK
Car: 240SXs
BUMP
robbbby
Once again, get a cable from a KA24DE.
llamabeta
Per this thread:
http://www.nicoclub.com/zerothread?id=62053
It says it does. I have a 92 240SX. I have the SR20DET sitting at my local terminal right now. I'll find out next weekend if a 92 cable will fit and still have the same routing.
Also if you dont get the SR20DE bracket, my understanding is that you can bend the existing SR20DET bracket to get it to work.
9095240SXDUCK
Car: 240SXs
Cool Just Got one from a 90s G20 lets see what happens!
Thanks Alot
